{"product_id":"axminster-workshop-aw300ds-300mm-disc-sander-230v","title":"Axminster Workshop AW300DS 300mm Disc Sander - 230V","description":"\u003cp\u003eThe AW300DS has an 300mm diameter aluminium disc driven by a quiet 750W induction motor. It has a no-volt-release switch and a brake to slow the disc down in a reasonable time.\u003c\/p\u003e\u003cp\u003eThe cast iron sanding table has a ground top surface with a slot for the mitre fence. The unique mitre fence has two faces at 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and can produce LH and RH 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bevels without resetting. The table tilts up to 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and firmly locks at both sides.\u003c\/p\u003e\u003cp\u003eEfficient dust extraction is via a 63mm outlet. A 450mm length of flexible hose is provided with the machine for connection to a vacuum or similar extractor.\u003c\/p\u003e\u003cp\u003eOverall, the AW300DS is solid, weighty and stable and does a good job when it comes to sanding to a line and similar tasks.\u003c\/p\u003e\u003cp\u003eSelf adhesive abrasive discs are available in a wide range of grits.\u003c\/p\u003e\u003cp\u003eTip: Self adhesive discs can easily be removed complete with their glue by gently warming with a hot air gun (or a simple hair drier) before removing.\u003c\/p\u003e\u003cp\u003ePlease note: these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118432014683,"sku":"107672","price":240.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107672_xl.jpg?v=1789779533","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw300ds-300mm-disc-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
