{"product_id":"axminster-workshop-aw315pd-bench-pillar-drill-230v","title":"Axminster Workshop AW315PD Bench Pillar Drill - 230V","description":"\u003cp\u003eA good size bench pillar drill enabling you to drill accurate holes at consistent depths and angles.\u003c\/p\u003e\u003cp\u003eMade from cast iron and machined steel it’s sturdy, stable and strong. The keyless chuck is an excellent feature with a capacity of 1 to 16mm. Powered by a 550W induction motor, there are 12 belt speeds to choose from between 210-2,580rpm. The down feed is fitted with soft grip handles and there is a convenient drilling depth control. Table height is controlled via a rack and pinion system, the whole table assembly can be swivelled away to allow the base to be used as a work support. A front mounted NVR switch and the adjustable chuck guard add to the convenience of use. The belt cover has a safety switch to ensure safe speed changing.\u003c\/p\u003e\u003cp\u003eA great choice for any hobby workshop.\u003c\/p\u003e\u003cp\u003ePlease note: the AW315PD is not suitable for a morticing attachment.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118432702811,"sku":"107691","price":289.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107691_xl.jpg?v=1789779592","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw315pd-bench-pillar-drill-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
