{"product_id":"axminster-workshop-aw3310s-spiral-planer-thicknesser-230v","title":"Axminster Workshop AW3310S Spiral Planer Thicknesser 230V","description":"\u003cp\u003eThe AW3310S Spiral Planer Thicknesser is engineered for smooth, accurate, and consistent results. Its spiral cutting block uses 30 knives arranged in two rows, offering a far longer service life than traditional HSS blades. With this design, planing ripple is virtually eliminated. When an edge eventually dulls, simply rotate the cutter 90° with the supplied Torx driver - tighten, and you’re back to work. There’s no resetting, no downtime, and no waiting for sharpened blades to return. Spiral blocks also run quieter and with significantly reduced vibration.\u003c\/p\u003e\u003cp\u003eThe alloy fence provides reliable support for precise work, and adjusts easily with stops at 90° and 45°. Switching between jointing and thicknessing is quick and intuitive thanks to the single-lift tables, which raise together in one smooth motion. A 5.4 m\/min feed speed ensures a consistently clean, smooth finish.\u003c\/p\u003e\u003cp\u003eAdjustments are straightforward: the digital height gauge makes adjustments simple, while a viewing window in the feed table allows easy monitoring during operation.\u003c\/p\u003e\u003cp\u003ePowered by a robust 3 kW motor, the AW3310S Spiral Planer Thicknesser handles a wide range of tasks with its 310 mm planing width and 230 mm thicknessing capacity. The maximum depth of cut when planing is 3 mm, whilst the maximum depth of cut for thicknessing is 4 mm.\u003c\/p\u003e\u003cp\u003eN.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118669680987,"sku":"113347","price":1899.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113347_xl.jpg?v=1789790885","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw3310s-spiral-planer-thicknesser-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
