{"product_id":"axminster-workshop-aw457ss-scroll-saw","title":"Axminster Workshop AW457SS Scroll Saw","description":"\u003cp\u003eThe Axminster Workshop AW457SS Scroll Saw is a versatile and precise tool, ideal for intricate woodworking projects.\u003c\/p\u003e\u003cp\u003ePowered by a 120W motor, it ensures smooth and accurate cuts with stroke length of 20mm. With adjustable strokes per minute ranging from 550 to 1,550\/min, you have full control over the cutting speed and can cut materials up to 50mm deep.\u003c\/p\u003e\u003cp\u003eThe table is 350 x 540mm with a 457mm throat depth. The arm tilts to 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e in both directions, for bevel cutting and is ideal for handling larger workpieces. The arm also raises to ensure quick blade threading when making internal pierced cuts. The base and table are made from a heavy gauge steel plate, giving stability and helps to reduce vibration.\u003c\/p\u003e\u003cp\u003eThe saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. Additionally, the 37mm dust extraction outlet keeps your workspace clean and free of debris when paired with a vacuum, making this scroll saw a valuable addition to any workshop.\u003c\/p\u003e\u003cp\u003eSuitable for wood, metal and plastic when using the correct blades.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118624526683,"sku":"111916","price":249.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111916_xl.jpg?v=1789788363","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw457ss-scroll-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
