The AW750DE Dust Extractor is a compact yet powerful solution for smaller workshops. Powered by a 750W motor, it delivers 795m³/hr airflow, ensuring to keep your workspace safe and clean. It's particularly effective when paired with machines that produce large volumes of waste, such as planer thicknessers.
Delivering 5-micron filtration, the dust extractor effectively captures larger dust particles and shavings with ease. Its balanced steel impeller ensures long life and consistent performance, even when connected to machines that generate heavy waste. Despite its performance, the dust extractor remains budget-friendly and provides simple and effective dust extraction.
Designed with practicality in mind, the AW750DE Dust Extractor is easy to move around the workshop thanks to its large wheels. Bag clips and quick-fit straps allow for fast and effortless bag changes, helping you keep the machine running with minimal downtime. Compact and robust, it integrates seamlessly into a busy workshop environment.
It has a bag capacity of 57L and features a single 100mm hose inlet, allowing easy connection to many types of machines.
Airflow: as measured in the Axminster Workshop 795m³/hr airflow @ 100mm.
Airflow 795 m³/hr @ 100 mm
Filter Performance 5 micron
Overall L x W x H 826 x 515 x 1580 mm
Power 750 W
Rating Regular Use
Sound Power Level LwA [Uncertainty K] 77 dB(A)
Plug Fitted UK 3 pin plug
Web Attribute Set Coarse Dust & Chippings Extractors
EAN Barcode 5052511142422
