The Bahco 244 Hardpoint Handsaws feature a universal tooth set with high frequency hardened teeth giving up to 5x the life of conventional teeth.
Particularly effective for cross cut and rip performance on chipboard, hardboard and hardwood. The plastic handle incorporates 45º and 90º marking guides and is securely screwed to the blade.
The Bahco 244-20-U7/8-HP Hard point Handsaw has the following specification:
Blade Length: 500mm (20
Tooth Pitch: 7 TPI.
Type: Universal Hard point
