The Bahco 244 Hardpoint Handsaws feature a universal tooth set with high frequency hardened teeth giving up to 5x the life of conventional teeth.
Particularly effective for cross cut and rip performance on chipboard, hardboard and hardwood. The plastic handle incorporates 45º and 90º marking guides and is securely screwed to the blade.
The 244 PRC saw is ideal for precision work, with fine toothing for a perfect result.
Cut: fine
Blade length: 550mm (22)
Type: Universal hardpoint
9 TPI
Web Attribute Set Handsaws
EAN Barcode 7311518288594
