The Bahco 2600 Superior Handsaw has been developed according to the scientific ERGO™ process. Its screwed three-component handle has been designed to fit perfectly in the hand, with superior handling and comfort when sawing. The handle can be used as an approximate 45° and 90° marking guide. Its unique hard point NXT teeth ensure long-lasting sharpness. With a low-friction, rust-protective coating for smoother cuts. The thicker blade provides increased stability and precision. Ideal for fast cutting in modern medium/hard materials such as chipboard or plastics. Specification Length: 550mm (22") TPI: 9
Web Attribute Set Handsaws
EAN Barcode 7311518160777
