The Bahco 59/S100BC Bit Set contains a wide selection of bits suitable for universal use. Each bit is made from high-performance alloy steel. TORX bits are colour coded to easily identify the size of the tip. Supplied in a durable carry case. Contains:17 x 25mm Phillips Bits: PH1(x2), PH2(x9), PH3 and PH2G(x5).12 x 25mm Pozidriv Bits: PZ1(x2), PZ2(x9) and PZ3.50 x 25mm TORX Bits: TX10(x3), TX15(x5), TX20(x15), TX25(x8), TX27, TX30(x15) and TX40(x3).5 x 25mm TORX Tamper-Resistant Bits: TTX10, TTX15, TTX20, TTX25 and TTX30.2 x 25mm Slotted Bits: 4.5 and 5.5mm.9 x 25mm Hexagon Bits: 3, 4(x3), 5, 6(x3) and 8mm.2 x 25mm Robertson Bits: #1 and #2.1 x KM653 Magnetic Universal Bit Holder.1 x KM653-QR Magnetic Quick-Release Bit Holder.1 x Socket Adaptor 1/4in.
Bahco
Bahco 59/S100BC Colour Coded Bit Set, 100 Piece
| Web Attribute Set | Screwdriver Bits |
| EAN Barcode | 7314150337637 |
