The blades are solid tungsten carbide, they will last up to one hundred times longer than conventional steel blades. Available in four shapes: 25mm triangular (giving three edges as well as three sharp points), 25mm circular, 22mm teardrop and 20mm pear shaped.
Bahco
Bahco Blades for 625 Pocket Carbide Scraper
| Web Attribute Set | Scrapers |
| EAN Barcode | 7311518221645 |
