These replaceable, twin edged blades last many times longer than conventional scraper blads. They are ideal for removing paint, glue, varnish and rust without the need for heat. The blades have convex ground edges to reduce the risk of scratching surfaces and cut on pull or push strokes. These tools find a use with woodworkers, restorers, boat builders and many others.
Bahco
Bahco Blades for 650 & 665 Carbide Scrapers
| Blade Length | 50 mm |
| Web Attribute Set | Scrapers |
| EAN Barcode | 7311518002848 |
