The Bahco 1-100 Hand files with handles are for filing flat surfaces, sharp corners and shoulders as well as for deburring. A double cut file may also be used for work in high-alloy tool steels. Also useful for the sharpening of heavy implements. High removal rate. Edges and surfaces parallel. Surfaces double cut, one edge uncut, one edge single cut.
Bahco
Bahco Handled Hand Files - 200mm
| File Length | 200 mm File Type: Hand Web Attribute Set: Engineers Files |
| EAN Barcode | 7311518003609 |
