Tools from Japan
Bester Imanishi Combination Waterstone - 1,000/6,000g
SKU: 502271
€39,00
  • Good balance of speed and wear-resistance
  • Moderately strong bond with fast cutting rate
  • Sharpens O1, A2 and M2 steels at a rapid rate
The Bester both worlds (if you'll pardon the pun), this stone offers both sharpening and honing options with one stone. Overall dimensions are 205mm x 75mm x 25mm. Simply soak in water for 10 to 15 minutes before use.
BESTER waterstones, manufactured by Imanishi in Kyoto, Japan have almost become the standard with Japanese professional woodworkers. They feature a moderately strong bond that allows abrasive particles to release quickly, maintaining a fast cutting rate, yet resist wear better. These stones behave similarly to a natural stone, the feedback tells you how fast it is cutting. Tests have shown they abrade O1, A2 and M2 steels at a rapid rate and remain flat just as long as slower cutting stones with stronger bonds.
Overall L x W x H 205 mm x 75 mm x 25 mm
Web Attribute Set Waterstones
EAN Barcode 5052511050949
