This 4,000 grit honing stone removes fine scratches on the bevel. The edge it produces is a great improvement over the coarser stones. Overall dimensions are 205mm x 75mm x 25mm. This fine stone has a resin bond and needs just a quick spray with water before use.
BESTER waterstones, manufactured by Imanishi in Kyoto, Japan have almost become the standard with Japanese professional woodworkers. They feature a moderately strong bond that allows abrasive particles to release quickly, maintaining a fast cutting rate, yet resist wear better. These stones behave similarly to a natural stone, the feedback tells you how fast it is cutting. Tests have shown they abrade O1, A2 and M2 steels at a rapid rate and remain flat just as long as slower cutting stones with stronger bonds.
Overall L x W x H 205 mm x 75 mm x 25 mm
Web Attribute Set Waterstones
EAN Barcode 5052511050925
