The Powerfile has become a much valued tool for getting into tight spots to sand, shape and remove rust. Fitted with a 13mm wide straight sanding arm with a reach of 120mm, it has variable speed control allowing it to sand a variety of materials like wood, metal, ceramics plaster, plastics etc. It is ergonomically balanced with a cyclonic dust collection cassette to keep the user and the environment clean. The dust cassette retains dust from the powerfile in a compact and efficient unit with a pleated filter element easily removed for cleaning and emptying. Powered by 350W variable speed motor the standard straight arm supplied supports an abrasive belt 13mm wide. Supplied with 3 sanding belts.
2 Year Black and Decker Warranty.
