Rider
Blade for Rider No. 62 Low Angle Jack Plane
SKU: 102729
£25.98
£21.65 Excl. VAT
  • High carbon steel blade 4mm thick to eliminates chatter
  • Each blade is oil quenched, for even tempering
  • Hardened to HRC 63 for a long lasting edge
  • 50mm (2) wide with 25 bevel
A spare or additional blade for the Rider No. 62 Low Angle Jack Plane. All the blades are oil quenched high carbon steel hardened to HRC 63 for a long lasting ultra sharp edge. Each is 4mm thick, ground with a 25 bevel.
Web Attribute Set Hand Plane Blades
EAN Barcode 5052511073221
