These blades feature impulse-hardened cutting edges for maximum durability. The toothed blades have Japanese style teeth giving a fast, smooth action and leaving a clean result. The range includes blades for cutting insulation or cardboard and one for plastic pipe cutting. There are blades for fine pruning, dry wood, and a keyhole or curve cutting blade as well as replacement general purpose blades. All the blades are 120mm long. Whatever your trade, there is a blade for you.
Saw Blade Type Keyhole/Curve Cutting 12 tpi
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511023400
