These blades feature impulse-hardened cutting edges for maximum durability. The toothed blades have Japanese style teeth giving a fast, smooth action and leaving a clean result. The range includes blades for cutting insulation or cardboard and one for plastic pipe cutting. There are blades for fine pruning, dry wood, and a keyhole or curve cutting blade as well as replacement general purpose blades. All the blades are 120mm long. Whatever your trade, there is a blade for you.
Length of Blade 120 mm
Saw Blade Type Standard/Pruning 10 tpi
EAN Barcode 5052511023417
