Veritas
Blades for Veritas Apron Plane
SKU: 506330
€37,00
  • PM-V11 3.2mm(1/8) thick
  • 31.75mm(1.1/4) wide
  • Lapped to a flatness tolerance of 0.005mm(0.0002)
In a nutshell, O1 steel is easy to hone and a very fine edge achieved relatively quickly. To add to the mix we now have the highly acclaimed PM-V11 alloy blades that are easier to sharpen than A2 and hold an extremely durable cutting edge for up to twice as long as A2. What does this mean in practice? If you’re roughing something to size or planing abrasive exotics then PM-V11 is probably the better choices. Lapped blades PM-V11 3.2mm(1/8) thick, 31.75mm(1.1/4) wide.
Plane Blade Type PM-V11
Web Attribute Set Hand Planes
