{"product_id":"bora-auto-adjust-horizontal-t-track-clamp","title":"BORA Auto Adjust Horizontal T-Track Clamp","description":"\u003cp\u003eThe BORA Auto Adjust T-Track Clamp 8mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) is a versatile, time-saving solution designed to streamline clamping across a wide range of woodworking and workshop tasks. Built to fit standard 8mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) T-tracks, it provides a secure and reliable hold while reducing the need for constant adjustments, making it ideal for both professional and hobby use.\u003c\/p\u003e\u003cp\u003eFeaturing an intelligent auto-adjust mechanism, the clamp automatically adapts to different material thicknesses, maintaining consistent pressure throughout your work. This helps improve accuracy, reduce setup time and keep projects moving efficiently. The 360-degree rotating clamp head allows for flexible positioning, making it easier to handle awkward setups or confined working areas.\u003c\/p\u003e\u003cp\u003eConstructed with a durable 8mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) T-bolt for dependable performance, this clamp is well suited to repeated, heavy-duty use. Whether used for routing, sanding, assembly or general bench work, it provides a stable and adaptable clamping solution across a variety of applications.\u003c\/p\u003e","brand":"Bora Tools","offers":[{"title":"Default Title","offer_id":54118865174875,"sku":"114390","price":50.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114390_xl.jpg?v=1789794878","url":"https:\/\/www.axminstertools.com\/products\/bora-auto-adjust-horizontal-t-track-clamp","provider":"Axminster Tools","version":"1.0","type":"link"}
