The BORA Auto Adjust In-Line T-Track Clamp is a versatile and efficient clamping solution designed for both woodworking and metalworking applications. Built to fit standard 8mm (5/16) T-track systems, it delivers a secure, stable hold while integrating seamlessly into your existing bench or jig setup. Its in-line design is particularly effective for controlling longer materials and maintaining alignment across extended workpieces.
Featuring an advanced auto-adjust mechanism, the clamp automatically adapts to varying material thicknesses, maintaining consistent pressure without the need for manual readjustment. This not only improves accuracy but also helps reduce setup time, making it ideal for repetitive or complex tasks where efficiency is key. The clamp is capable of handling materials up to 95mm (3.75) thick, offering flexibility across a wide range of applications.
A 360-degree rotating clamp head adds further versatility, allowing precise positioning in tight or awkward setups. Combined with a durable 8mm (5/16) T-bolt for reliable performance, this clamp is built for regular, demanding use in professional and workshop environments.
EAN Barcode 9341231064326
