The BORA Centipede 0.6m x 1.2m (2' x 4') Workstand is a highly portable, heavy-duty solution designed to create a stable and flexible workspace wherever you need it. Expanding quickly from a compact folded size into a full 0.6m x 1.2m workstation at a comfortable 762mm (30
Despite its lightweight, collapsible design, this Centipede unit delivers impressive strength, supporting up to 2,500lbs when evenly distributed. Its robust steel strut system flexes to absorb impact while maintaining stability, making it suitable for handling sheet materials, power tools and demanding workloads without compromise.
The durable polymer P-Tops protect your workpiece from marks and prevent potential damage to the structure, while their 360-degree rotation allows for easy positioning and compatibility with a wide range of Centipede accessories. This makes it easy to customise your setup for cutting, assembly or general bench work.
Designed for versatility, the system includes Quick Clamps and X-Cups to secure materials firmly in place, helping improve accuracy and safety. When the job is done, the workstand folds down into a compact size for easy transport and storage, complete with a carry bag for added convenience.
BORA Tools is known for creating innovative, adaptable solutions that improve efficiency on-site and in the workshop. With a focus on portability, strength and ease of use, the Centipede system is engineered to provide a dependable workspace without the limitations of a fixed bench.
The workstand measures 0.6m x 1.2m when set up and folds down to approximately 15.2 cm x 22.9 cm x 96.5 cm (6
Supplied with workstand, two Quick Clamps, four X-Cups and a carry bag.
