The BORA Centipede Table Top Pair with 20mm dog holes is designed to transform your Centipede workstand into a stable, fully functional workstation. Featuring evenly spaced 20mm dog holes across the surface, it provides excellent compatibility with a wide range of clamping accessories for accurate, repeatable setups.
Each tabletop attaches quickly and securely using the included quick-twist lock handles, ensuring a firm connection to your Centipede base. With a high load capacity of up to 907kg (2000lbs), it offers reliable support for demanding workshop and site tasks. Depending on your Centipede model, multiple tops can be combined to achieve full surface coverage, giving you a flexible and scalable workspace solution.
