The BORA Dog Fence Clamping Accessory is a versatile and reliable solution designed to improve accuracy, stability and workflow across a wide range of woodworking tasks. Available in 4, 8 and 14 sizes, it provides flexible material support for everything from compact setups to larger workpieces, making it ideal for both workshop and on-site use. Whether you are sanding, routing or assembling, this adaptable system helps ensure consistent, repeatable results.
Designed with a reversible high and low profile, the dog fence easily accommodates different material thicknesses and project requirements. This dual-sided functionality makes it particularly effective for precision tasks, allowing you to quickly adjust your setup without interrupting workflow. The fence helps brace and position materials securely, improving control and overall finish quality.
Each fence is supplied with adjustable bench dog pegs, allowing for quick and accurate positioning within standard 3/4 dog holes. The easy slide-in design enables fast adjustments, helping you fine-tune spacing, align workpieces and create stable corner or edge setups with minimal effort. This makes it especially useful when handling longer boards or repeat tasks where consistency is key.
BORA Tools is known for producing innovative, problem-solving equipment that enhances efficiency for woodworkers, tradespeople and DIY users. With a focus on practical design and dependable performance, BORA products are built to simplify workshop tasks while delivering professional-level precision and reliability.
The dog fence is compatible with standard 3/4 diameter dog-hole systems and features a reversible structure for high and low clamping configurations. Adjustable peg fences support accurate positioning, while the range of available sizes (4, 8 and 14) ensures suitability for a variety of applications.
Supplied as a BORA Dog Fence Clamping Accessory in your selected size, complete with two adjustable bench dog pegs for immediate use with compatible workbench systems.
EAN Barcode 9341231064890
