The BORA 6 Driver Bit is a reliable, extended-length accessory designed to improve access and control during pocket hole joinery and assembly tasks. Its 6-inch reach makes it ideal for working in tight or confined spaces, allowing you to drive screws with greater ease and accuracy.
Built for durability and precision, this driver bit is compatible with drills that accept interchangeable bits, making it a versatile addition to any woodworking or cabinetry setup. Whether assembling furniture, cabinets or frames, it delivers consistent performance on every job.
Web Attribute Set Pocket Hole Jigs & Accessories
EAN Barcode 9341231064517
