The BORA PRO Compact Pocket Hole Jig is a durable and efficient solution designed to deliver precise, repeatable joinery in a compact form. Built with a robust powder-coated metal block, it minimises flex and vibration during drilling, helping ensure smooth, accurate pocket holes every time, even in tighter working spaces.
Its self-calibrating body automatically measures the thickness of your material, removing the need for manual setup and reducing the risk of error. This allows for faster workflow and consistent results across multiple joints. The integrated colour-coded screw system provides quick visual reference, making it easier to select the correct fixings for each application.
Designed with practicality in mind, the jig includes non-slip pads to hold it securely in place while protecting your work surface from damage. Hardened drill bushes enhance durability and accuracy over time, while onboard storage keeps essential accessories like the drill bit and Allen key close at hand for convenience on the job.
