{"product_id":"bosch-15-piece-router-cutter-set-1-4","title":"Bosch 15 Piece Router Cutter Set - 1\/4\"","description":"\u003cp\u003eThis router bit set from Bosch comprises 15 well chosen, high quality TCT router cutters. For anyone who owns a router that can take 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank cutters this is a handy set of 15 very useful bits. All 15 can be used in hand held routers, in routers fixed in tables.\u003c\/p\u003e\u003cp\u003eContents:\u003c\/p\u003e\u003cp\u003e1 x 12\u003cspecial id=\"8\"\u003e\u003c\/special\u003e Dovetail cutter x 14mm(9\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e V-groove cutter x 16mm(5\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 4mm(5\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) bearing guided Slotting cutter x 32mm(1.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x Bearing guided Rebating cutter x 32mm(1.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x Bearing guided Roman ogee cutter 4mm(5\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius x 27mm(1.1\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x Bearing guided Cove cutter 9.5mm(3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius x 28.5(1.\/18\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x Straight cutter 6.3mm(1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) x 20mm(25\/32\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x Straight cutter 12.7mm(1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) x 30mm(1.3\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x Straight cutter 16mm(5\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) x 30mm(1.3\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) depth of cut\u003c\/p\u003e\u003cp\u003e1 x 3.2mm(1\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius bearing guided Rounding over cutter x 19mm(3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 6.35mm(1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius bearing guided Rounding over cutter x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 25\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bearing guided Chamfer cutter x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bearing guided Chamfer cutter x 35mm(1.3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 12.7mm(1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter Flush cutter with bottom bearing x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003e1 x 16mm(5\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter Flush cutter with top bearing x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003eThe flush cutters allow you to trim or follow a profile fixed above or below the workpiece.\u003c\/p\u003e\u003cp\u003eThe robust storage case also includes spare bearings and a hex key.\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54118442533211,"sku":"107995","price":82.22,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107995_xl.jpg?v=1789780267","url":"https:\/\/www.axminstertools.com\/products\/bosch-15-piece-router-cutter-set-1-4","provider":"Axminster Tools","version":"1.0","type":"link"}
