This router bit set from Bosch comprises 15 well chosen, high quality TCT router cutters. For anyone who owns a router that can take 1/4 shank cutters this is a handy set of 15 very useful bits. All 15 can be used in hand held routers, in routers fixed in tables.
Contents:
1 x 12 Dovetail cutter x 14mm(9/16) diameter
1 x 60 V-groove cutter x 16mm(5/8) diameter
1 x 4mm(5/32) bearing guided Slotting cutter x 32mm(1.1/4) diameter
1 x Bearing guided Rebating cutter x 32mm(1.1/4) diameter
1 x Bearing guided Roman ogee cutter 4mm(5/32) radius x 27mm(1.1/16) diameter
1 x Bearing guided Cove cutter 9.5mm(3/8) radius x 28.5(1./18) diameter
1 x Straight cutter 6.3mm(1/4) x 20mm(25/32) depth of cut
1 x Straight cutter 12.7mm(1/2) x 30mm(1.3/16) depth of cut
1 x Straight cutter 16mm(5/8) x 30mm(1.3/16) depth of cut
1 x 3.2mm(1/8) radius bearing guided Rounding over cutter x 19mm(3/4) diameter
1 x 6.35mm(1/4) radius bearing guided Rounding over cutter x 25.4mm(1) diameter
1 x 25 bearing guided Chamfer cutter x 25.4mm(1) diameter
1 x 45 bearing guided Chamfer cutter x 35mm(1.3/8) diameter
1 x 12.7mm(1/2) diameter Flush cutter with bottom bearing x 25.4mm(1)
1 x 16mm(5/8) diameter Flush cutter with top bearing x 25.4mm(1)
The flush cutters allow you to trim or follow a profile fixed above or below the workpiece.
The robust storage case also includes spare bearings and a hex key.
