{"product_id":"bosch-6-piece-router-cutter-set-1-4","title":"Bosch 6 Piece Router Cutter Set - 1\/4\"","description":"\u003cp\u003eThis router bit set from Bosch comprises six well chosen, high quality TCT router cutters. For anyone who owns a router that can take 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) shank cutters this is a handy set of six very useful bits. All six cutters feature bearing guides and can be used in hand held routers, in routers fixed in tables and on straight or curved work.\u003c\/p\u003e\u003cp\u003eContents:\u003c\/p\u003e\u003cp\u003e1 x 3.2mm(1\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius bearing guided Rounding over cutter x 19mm(3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 6.35mm(1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) radius bearing guided Rounding over cutter x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 25\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bearing guided Chamfer cutter x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e bearing guided Chamfer cutter x 35mm(1.3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter\u003c\/p\u003e\u003cp\u003e1 x 12.7mm(1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter Flush cutter with bottom bearing x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003e1 x 16mm(5\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) diameter Flush cutter with top bearing x 25.4mm(1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003eThe flush cutters allow you to trim or follow a profile fixed above or below the workpiece.\u003c\/p\u003e\u003cp\u003eThe robust storage case also includes spare bearings and a hex key\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54118442402139,"sku":"107994","price":38.12,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107994_xl.jpg?v=1789780257","url":"https:\/\/www.axminstertools.com\/products\/bosch-6-piece-router-cutter-set-1-4","provider":"Axminster Tools","version":"1.0","type":"link"}
