{"product_id":"bosch-gcm-12-gdl-305mm-axial-glide-mitre-saw","title":"Bosch GCM 12 GDL 305mm Axial-Glide Mitre Saw","description":"\u003cp\u003eThis unique saw features Bosch’s 'Axial-Glide'\u003cspecial id=\"10\"\u003e\u003c\/special\u003esystem, which provides the smoothest and most precise cutting action of any mitre saw on the market today. Rather than using guide bars, the GCM 12 GDL features vertical and horizontal hinged arms with sealed bearings. The arrangement guarantees a maintenance-free, super smooth and highly accurate action.\u003c\/p\u003e\u003cp\u003eIn addition, the design saves space. You do not need to allow for guide bars projecting to the rear and as the controls for setting mitre and bevel cuts are at the front of the machine; you can position the GCM 12 GDL against a wall. The saw has a large cutting capacity and wide ranges of both mitre and bevel angles. A laser projects a dual line defining each side of the kerf for precise line-up before cutting. A depth of cut limiter allows you to groove or rebate.\u003c\/p\u003e\u003cp\u003eThe table has pull out material supports right and left, with stops for repeat cuts. The back fence, with a total length of 1,016mm offers maximum work support. The Axial-Glide\u003cspecial id=\"10\"\u003e\u003c\/special\u003e system locks for transport.\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54117478728027,"sku":"501681","price":1089.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/501681_xl.jpg?v=1790100590","url":"https:\/\/www.axminstertools.com\/products\/bosch-gcm-12-gdl-305mm-axial-glide-mitre-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
