{"product_id":"bosch-gho18v-26-brushless-planer-18v-body-only","title":"Bosch GHO18V-26 Brushless Planer 18V (Body Only)","description":"\u003cp\u003eBosch PRO GHO 18V-26 Cordless Planer delivers the freedom of cordless working with the performance and precision expected from a professional woodworking tool. Designed for planing natural and manufactured timber, it quickly removes material to create smooth, flat surfaces with a high-quality finish.\u003c\/p\u003e\u003cp\u003ePrecision engineered for consistent flatness, the GHO 18V-26 features a powerful Bosch brushless motor that delivers performance comparable to a corded planer. The dual-blade TC blade changing system allows fast blade replacement without adjustment, helping to reduce downtime and keep you working efficiently.\u003c\/p\u003e\u003cp\u003eWith a maximum planing width of 82mm, a rebating depth of up to 9mm and a no-load speed of 13,600rpm, the planer is well suited to a wide range of workshop and site applications. Improved dust management with dual chip ejection helps keep the work area cleaner, while three chamfer grooves make it easy to produce accurate bevelled edges.\u003c\/p\u003e\u003cp\u003eBosch Professional tools are engineered for demanding trade and workshop use, offering the durability, performance and reliability professionals rely on every day.\u003c\/p\u003e\u003cp\u003eIdeal for joiners, carpenters, cabinet makers and furniture makers, the GHO 18V-26 is perfect for flattening surfaces, trimming doors and general timber fitting work.\u003c\/p\u003e\u003cp\u003eBody only, not supplied with battery or charger.\u003c\/p\u003e\u003cp\u003ePart of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.\u003c\/p\u003e\u003cp\u003eSupplied with dust bag, parallel guide and spare planer blade stored within the tool.\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54118869860699,"sku":"114461","price":219.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114461_xl.jpg?v=1789795230","url":"https:\/\/www.axminstertools.com\/products\/bosch-gho18v-26-brushless-planer-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
