This oscillating Multi-tool is fitted with the high performance EC brushless motor. These motors are extremely energy efficient resulting in much longer battery run times (30% more than a standard DC motor). Brushless motors are maintenance-free, compact and lightweight.
The GOP 18 V-34 features the Starlock accessory mounting system. Starlock is a joint development by Bosch and Fein. This
The GOP 18 V-34 will take both standard Starlock and Starlock Plus accessories, giving you a wide range of cutting, sanding, grinding and polishing options. It can also cut PVC or metal, remove grout from tiles or for scraping off residues. The 3.4
It features a slimmer body than the previous model, with a circumference of just 180mm to make sure you have control and maximum comfort when working.
Part of the multi-brand AMPShare battery system, offering flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPShare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
This is a body only tool, supplied without batteries or charger. Supplied with a Starlock Plus BIM Plunge Cut saw blade BIM 32mm with curve-Tec for wood and metal cutting.
