{"product_id":"bosch-gsa-18v-24-brushless-sabre-saw-18v-body-only","title":"Bosch GSA 18V-24 Brushless Sabre Saw 18V (Body Only)","description":"\u003cp\u003eBosch PRO GSA 18V-24 Cordless Reciprocating Saw combines compact dimensions with impressive cutting performance, making it ideal for working in confined spaces and awkward positions. Designed for professional tradespeople, its ergonomic design allows easier handling when cutting close to walls, between joists and in other hard-to-reach areas.\u003c\/p\u003e\u003cp\u003eWith an outstanding power-to-weight ratio, the GSA 18V-24 delivers fast, powerful cuts while remaining comfortable to use throughout the working day. An optimised 24mm stroke length and variable stroke rate of up to 3,100 strokes per minute provide rapid cutting performance across a wide range of materials. The innovative counter-balance mechanism reduces vibration, improving control and helping to minimise fatigue.\u003c\/p\u003e\u003cp\u003ePowered by a high-performance brushless motor, the saw features variable speed control, a tool-free SDS blade holder for quick blade changes, a pivoting footplate for added stability and an integrated LED work light. Weighing just 1.7kg excluding battery, it offers a maximum cutting depth of 230mm in wood. Ideal for use in the workshop and on site as well as in the garden for joiners and builders, HVAC installers, plumbers, electricians, the GSA 18V-24 is a versatile all-round cutting solution for wood, metal and plastics with the right blade fitted.\u003c\/p\u003e\u003cp\u003eBosch Professional tools are engineered for demanding trade and site use, delivering the performance, durability and reliability professionals expect.\u003c\/p\u003e\u003cp\u003ePart of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.\u003c\/p\u003e\u003cp\u003eBody only, not supplied with battery or charger.\u003c\/p\u003e\u003cp\u003eSupplied with an S 2345 X Progressor for Wood reciprocating saw blade and an S 922 EF Flexible for Metal reciprocating saw blade.\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54118869827931,"sku":"114460","price":149.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114460_xl.jpg?v=1789795221","url":"https:\/\/www.axminstertools.com\/products\/bosch-gsa-18v-24-brushless-sabre-saw-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
