This sturdy GTA2600 folding stand is suitable for mitre saws and using the tool mounting clamps many other machines can easily be mounted on to it. Adjustable work supports are fitted left and right these are height adjustable and can be extended to the required length for total work support. The legs have rubber end caps and one has 30mm adjustment for uneven floors, the legs are locked into position in use and can be folded easily for transport. Two tool clamps are supplied and these once fitted to your machine clamp simply to the stand with a safety lock.
Web Attribute Set Mitre Saw Stands Globale Group: low-margin-eu
EAN Barcode 3165140526128
