{"product_id":"bosch-hss-twist-pointteq-drill-bit-set-7","title":"Bosch HSS Twist PointTeQ Drill Bit Set 7","description":"\u003cp\u003eThe Bosch HSS Twist PointTeQ 7-Piece Drill Bit Set is designed for fast, accurate drilling in wood, manmade boards, metal and plastics. Featuring a self-centering PointTeQ 135 degree tip to drill cleanly, these drill bits start quickly without wandering, while reducing heat build-up and wear.\u003c\/p\u003e\u003cp\u003eThe highly elastic HSS body helps minimise breakage, and the black oxide coated flute ensures efficient chip removal for reliable performance.\u003c\/p\u003e\u003cp\u003eSuitable for use in drill drivers and drill stands, the set contains seven popular sizes for a wide range of drilling applications.\u003c\/p\u003e\u003cp\u003eSupplied as a set of 7 in a storage case;  2, 3, 4, 5, 6, 8 and 10mm.\u003c\/p\u003e","brand":"Bosch","offers":[{"title":"Default Title","offer_id":54118870417755,"sku":"114601","price":10.74,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114601_xl.jpg?v=1789795307","url":"https:\/\/www.axminstertools.com\/products\/bosch-hss-twist-pointteq-drill-bit-set-7","provider":"Axminster Tools","version":"1.0","type":"link"}
