The Bosch HSS Twist PointTeQ 7-Piece Drill Bit Set is designed for fast, accurate drilling in wood, manmade boards, metal and plastics. Featuring a self-centering PointTeQ 135 degree tip to drill cleanly, these drill bits start quickly without wandering, while reducing heat build-up and wear.
The highly elastic HSS body helps minimise breakage, and the black oxide coated flute ensures efficient chip removal for reliable performance.
Suitable for use in drill drivers and drill stands, the set contains seven popular sizes for a wide range of drilling applications.
Supplied as a set of 7 in a storage case; 2, 3, 4, 5, 6, 8 and 10mm.
Web Attribute Set Drill Bit Sets
EAN Barcode 3165140917650
