Bosch high speed drill bit set has PointTeq drill bits with a 135 degree tip, designed for metal drilling they are also suitable for hard and soft wood and plastics. The PointTeQ self centering tip design remains sharp and ensures high durability and fast drilling with low breakage due to a high elastic body, they have a black oxide coated flute. Supplied in a range of metric sizes. DIN 338, Type N.
Bosch
Bosch HSS Twist PointTeQ Drill Bits
| Pack Quantity | 2 |
| Drill Bit Diameter | 1.5 mm |
| Overall Length \ Working Length | 34 mm 18 mm |
| Web Attribute Set | Drill Bits |
| EAN Barcode | 3165140906630 |
