The Bosch PRO Impact Screwdriver Bit Set (36 Piece) is an excellent choice for interior fitters and installers who require durable, reliable bits for demanding applications. Designed for impact use, the screwdriver bits feature a built‑in torsion zone that absorbs torque at the tip, reducing stress and helping to prevent breakage.
For fast and easy identification, the bits are fitted with colour‑coded rings to indicate head type, along with laser markings for improved visibility. The set is supplied in a practical Pick and Click storage case for convenient organisation and transport.
Contents include:
25mm bits
5 × Phillips: PH1, PH2 (x3), PH3
3 × Pozidriv: PZ2 (x2), PZ3
8 × TORX: T15, T20 (x2), T25 (x2), T30 (x2), T40
55mm bits
2 × Phillips: PH2
2 × Pozidriv: PZ2
3 × TORX: T20, T25, T30
65mm double‑ended bits
2 × Phillips: PH1/PH2, PH2/PH3
2 × Pozidriv: PH2/PZ2 (x2)
3 × TORX: T15/T20 (x2), T25/T30
1 × Slotted: SL1 × 5.5 / SL1 × 5.5
Additional accessories
1 × Standard bit holder 60mm
1 × Quick‑change bit holder 60mm
3 × Nutsetters: 8, 10 & 13mm
