Fast, straight cut, flexible and break resistant, thick metal plate 3 - 8mm, solid pipes/profiles diameters up to 100mm. Pkt of 5 blades.
Blade Type Bi-metal, Milled and Side Set
Tooth Pitch \ tpi 1.81 mm \ 14 tpi
Model S922BF (Pkt 5) Web Attribute Set: Sabre Saws Blades Sabre Saw Blade Cutting Capacity: up to 100 mm Sabre Saw Blade Length: 150 mm
EAN Barcode 3165140093507
