A range of circular saw blades from the Bosch 'Top Precision' range for precise clean and quiet cuts in all types of wood. Suitable for 165mm handheld saws especially the GKT55GCE plunge saw. Blades have a thin kerf of 1.8mm and a 20mm bore, 48 teeth.
Blade Diameter 165 mm
Maximum RPM 11,500 rpm
Kerf 1.8 mm
Teeth 48
Tooth Format ATB
Plate Thickness 1.3 mm
Hook Angle 5
Bore Size 20 mm
Blade Application Universal (48 teeth)
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 3165140636858
