A range of circular saw blades from the Bosch 'Top Precision' range for precise clean and quiet cuts in all types of wood. Suitable for 165mm handheld saws especially the GKT55GCE plunge saw. Blades have a thin kerf of 1.8mm and a 20mm bore, 48 teeth.
Bosch
Bosch Top Precision TCT Saw Blades - 165mm x 1.8mm x 20mm
| Blade Diameter | 165 mm |
| Maximum RPM | 11,500 rpm |
| Kerf | 1.8 mm |
| Teeth | 48 |
| Tooth Format | ATB |
| Plate Thickness | 1.3 mm |
| Hook Angle | 5 |
| Bore Size | 20 mm |
| Blade Application | Universal (48 teeth) |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 3165140636858 |
