{"product_id":"carbide-cutter-for-evolution-series-probe-with-screw-key","title":"Carbide Cutter for Evolution Series Probe with Screw \u0026 Key","description":"\u003cp\u003eThis 8mm diameter, circular cup shaped cutter is a fine grade, solid tungsten carbide. It is a replacement to fit the straight and the cranked Axminster Evolution Series Probes.\u003c\/p\u003e\u003cp\u003eThe edge of the cutter is sharp and ready to use. Being solid tungsten carbide, it will retain its sharp edge for a very long time, far longer than any HSS equivalent.\u003c\/p\u003e\u003cp\u003eThe great advantage of the circular shape, comes when the cutter eventually begins to lose its edge. Then you simply slacken the retaining screw and rotate the cutter slightly to give you a new sharp edge. With a full 360\u003cspecial id=\"8\"\u003e\u003c\/special\u003e available, these cutters have a greatly extended working life.  The cutters can take a clean shaving and leave a very smooth surface straight from the edge.\u003c\/p\u003e\u003cp\u003eEach cutter includes a Torx wrench for the fixing screw.\u003c\/p\u003e","brand":"Crown","offers":[{"title":"Default Title","offer_id":54118255755611,"sku":"103654","price":23.38,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103654_xl.jpg?v=1789773173","url":"https:\/\/www.axminstertools.com\/products\/carbide-cutter-for-evolution-series-probe-with-screw-key","provider":"Axminster Tools","version":"1.0","type":"link"}
