A range of matching chapter rings and hands to go with our quartz clock movements. The chapter rings are either a silver or gold finish, with a 152mm diameter, with Arabic numerals, and the hands are available in a choice of designs in brass or black finish. A seconds hand is included with each set of hands; this can be discarded if not required but in this case the centre boss should be retained and used to blank off the drive shaft on the movement.
