{"product_id":"chestnut-cutnpolish-abrasive-wax-225ml","title":"Chestnut Cut'n'Polish Abrasive Wax - 225ml","description":"\u003cp\u003eThis wax is seriously impressive. It is a specialist wax produced mainly for woodturning. It is easy to apply, hard wearing and buffs to a high sheen.\u003c\/p\u003e\u003cp\u003eCut 'n' Polish has a fine abrasive held in suspension in a blend of two waxes. Cut 'n' Polish is a soft wax designed to stay 'wet' slightly longer during application, allowing it to lubricate the abrasive to give a very fine cut to the timber. At the same time, it collects any dust generated during use and from prior sanding preventing the dust from entering the workshop atmosphere.\u003c\/p\u003e\u003cp\u003eOn bare wood, sand to 240 grit as normal, apply a coat of Cut 'n' Polish with the lathe stopped, then switch on the lathe and buff to a soft sheen while smoothing the timber at the same time. On sealed wood, apply after the sealer in the same way, polishing to a higher shine.\u003c\/p\u003e\u003cp\u003eCut ’n’ Polish dries quickly; you can overcoat it if you wish with Chestnut Friction Polish or carnauba wax for a higher shine.\u003c\/p\u003e","brand":"Chestnut","offers":[{"title":"Default Title","offer_id":54118300680539,"sku":"104580","price":12.18,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104580_xl.jpg?v=1789774401","url":"https:\/\/www.axminstertools.com\/products\/chestnut-cutnpolish-abrasive-wax-225ml","provider":"Axminster Tools","version":"1.0","type":"link"}
