This Chestnut High Gloss Wax is a blend of high quality waxes in carnauba wax, perfect for achieving a deep shine and high gloss finish.
The wax should be used over one of Chestnut's sanding sealers and left to dry for approximately 20 minutes, before buffing to a shine. For best results, apply a very thin coat and spread evenly across the surface. For interior use only.
Also can be used on the Buffing Wheel System (101742). Use the A and B wheel as normal, apply the Microcrystalline Wax to your item. Allow 10 minutes for the wax to dry and buff using the C wheel. You can use the same C Wheel for the High Gloss Wax and the Carnuaba Wax Stick (101723).
This woodworking wax has been tested to the EN71 Part 3 regulations regarding coatings used on toys. The High Gloss Wax is also food safe once the solvent has fully evaporated, similar to the Microcrystalline Wax.
