{"product_id":"chestnut-high-gloss-wax-225ml","title":"Chestnut High Gloss Wax - 225ml","description":"\u003cp\u003eThis Chestnut High Gloss Wax is a blend of high quality waxes in carnauba wax, perfect for achieving a deep shine and high gloss finish.\u003c\/p\u003e\u003cp\u003eThe wax should be used over one of Chestnut's sanding sealers and left to dry for approximately 20 minutes, before buffing to a shine. For best results, apply a very thin coat and spread evenly across the surface. For interior use only.\u003c\/p\u003e\u003cp\u003eAlso can be used on the Buffing Wheel System (101742). Use the A and B wheel as normal, apply the Microcrystalline Wax to your item. Allow 10 minutes for the wax to dry and buff using the C wheel. You can use the same C Wheel for the High Gloss Wax and the Carnuaba Wax Stick (101723).\u003c\/p\u003e\u003cp\u003eThis woodworking wax has been tested to the EN71 Part 3 regulations regarding coatings used on toys. The High Gloss Wax is also food safe once the solvent has fully evaporated, similar to the Microcrystalline Wax.\u003c\/p\u003e","brand":"Chestnut","offers":[{"title":"Default Title","offer_id":54255606858075,"sku":"114812","price":11.38,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114812_xl.jpg?v=1791241996","url":"https:\/\/www.axminstertools.com\/products\/chestnut-high-gloss-wax-225ml","provider":"Axminster Tools","version":"1.0","type":"link"}
