A clear easily sanded sealer, containing a high proportion of shellac. Slower drying than cellulose it is easier to apply to large areas, not such a problem to keep a wet edge. More suited to cabinetmaking, it also has special additives to prevent the shellac forming a hard lump in the bottom of the bottle. Use to seal prior to French polishing or applying fine paste wax.
Chestnut
Chestnut Shellac Sanding Sealer
| Coverage | 6 m to 10 m per litre |
| Application Method | Brush Rag or Cloth Spray |
| Drying Time | 20 minutes |
| Clean Up | Methylated Spirits |
| Available Sizes | 1 litre |
| Web Attribute Set | Grain Filling & Sealing |
| EAN Barcode | 5060095030134 |
