Tung is natural oil used extensively as the base of many finishing products and in its pure state as a heat and moisture resistant finish on furniture and fittings, worktops and table tops around the home and outdoors. Pressed from a nut, Tung Oil has been used for centuries in the Orient as a supremely resistant decorative finish for wood. Easily applied by cloth or brush, observing the instructions for the use of organic oils. Coverage: approx 6 - 8m
Chestnut
Chestnut Tung Oil
| Coverage | 6 m to 8 m per litre |
| Application Method | Brush Rag or Cloth |
| Drying Time | 12 hours |
| Clean Up | White Spirit |
| Available Sizes | 500 ml |
| Web Attribute Set | Oil Finishes |
| EAN Barcode | 5060095030424 |
