{"product_id":"cmt-271-itk-plus-circular-saw-blades-general-purpose-thin-kerf","title":"CMT 271 ITK Plus Circular Saw Blades - General Purpose Thin Kerf","description":"\u003cp\u003eCMT ITK PLUS® General Purpose Thin Kerf Circular Saw Blades are versatile, professional-quality blades designed for both ripping and crosscutting. The thin kerf design removes less material with each cut, producing less waste and reducing cutting resistance. This allows the blade to pass through softwood, hardwood, plywood, OSB, MDF and other wood-based sheet materials more efficiently, placing less load on the saw and motor. When used with cordless tools, the reduced power demand can also help maximise battery runtime between charges.\u003c\/p\u003e\u003cp\u003eHigh-density micrograin carbide teeth provide excellent wear resistance and long-lasting cutting performance. The alternate top bevel (ATB) tooth configuration and 8° shear angle score and slice wood fibres cleanly during both rip and crosscuts, helping to reduce tear-out and deliver an improved surface finish with less cutting effort.\u003c\/p\u003e\u003cp\u003eThese circular saw blades from CMT feature laser-cut expansion slots, which reduce vibration and noise and allow safe expansion as the blade heats up, maintaining cutting accuracy and stability throughout prolonged use.\u003c\/p\u003e\u003cp\u003eFinished with CMT's Orange Shield® PTFE non-stick coating, the blade resists resin build-up, reduces friction for smoother cutting, and offers added protection against corrosion. Suitable for use with circular saws, mitre saws and table saws, it is an ideal all-round blade for softwood, hardwood, plywood, OSB, MDF and other wood-based sheet materials.\u003c\/p\u003e\u003cp\u003eFor details of each specific blade, see below:\u003c\/p\u003e\u003cp\u003e114693: CMT 271.136.18H; 136mm x bore size 20mm (+10mm spacer); hook angle 20⁰; ATB 10⁰\u003c\/p\u003e\u003cp\u003e114694: CMT 271.160.24H; 160mm x bore size 20mm (+16mm spacer); hook angle 18⁰; ATB 10⁰\u003c\/p\u003e\u003cp\u003e114695: CMT 271.165.24H; 165mm x bore size 20mm (+15.88mm spacer); hook angle 18⁰; ATB 10⁰\u003c\/p\u003e\u003cp\u003e114687: CMT 271.168.28H; 168mm x bore size 20mm; hook angle 15⁰; ATB 15⁰\u003c\/p\u003e\u003cp\u003e114697: CMT 271.190.24M; 190mm x bore size 30mm (+20 and 16mm spacers); hook angle 20⁰; ATB 10⁰\u003c\/p\u003e\u003cp\u003e114698: CMT 271.250.42M; 250mm x bore size 30mm; hook angle 18⁰; ATB 10⁰\u003c\/p\u003e\u003cp\u003e114699: CMT 271.305.48M; 305mm x bore size 30mm; hook angle -5⁰; ATB 10⁰\u003c\/p\u003e","brand":"CMT","offers":[{"title":"168 mm \/ 28 \/ 1.8 mm","offer_id":54438936183131,"sku":"114687","price":19.72,"currency_code":"GBP","in_stock":false},{"title":"136 mm \/ 18 \/ 1.5 mm","offer_id":54438936215899,"sku":"114693","price":12.7,"currency_code":"GBP","in_stock":true},{"title":"160 mm \/ 24 \/ 1.8 mm","offer_id":54438936248667,"sku":"114694","price":16.12,"currency_code":"GBP","in_stock":true},{"title":"165 mm \/ 24 \/ 1.7 mm","offer_id":54438936281435,"sku":"114695","price":16.12,"currency_code":"GBP","in_stock":true},{"title":"190 mm \/ 24 \/ 1.7 mm","offer_id":54438936314203,"sku":"114697","price":20.42,"currency_code":"GBP","in_stock":true},{"title":"250 mm \/ 42 \/ 2.4 mm","offer_id":54438936346971,"sku":"114698","price":43.33,"currency_code":"GBP","in_stock":true},{"title":"305 mm \/ 48 \/ 2.6 mm","offer_id":54438936379739,"sku":"114699","price":61.81,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114693_xl.jpg?v=1792543766","url":"https:\/\/www.axminstertools.com\/products\/cmt-271-itk-plus-circular-saw-blades-general-purpose-thin-kerf","provider":"Axminster Tools","version":"1.0","type":"link"}
