Designed for clean, accurate finishing cuts in solid timber and wood-based sheet materials, the thin kerf design of the CMT ITK PLUS® Finishing Thin Kerf Circular Saw Blades removes less material with each cut, producing less waste and reducing cutting resistance. This allows the blade to pass through hardwoods, softwoods, plywood, melamine and laminated panels more efficiently, placing less load on the saw and motor. When used with cordless tools, the reduced power demand can also help maximise battery runtime between charges.
Alternate top bevel (ATB) cutting teeth with an 8° shear angle create a slicing cutting action that leaves a finer finish on plywood, melamine, laminate and hardwood, making it an excellent choice for precision joinery, cabinetry and interior finishing work.
Built around a precision laser-cut steel body, the blades feature laser-cut expansion slots to reduce vibration and noise, as well as CMT's Orange Shield® PTFE coating to minimise friction, resin build-up and overheating for consistently smooth, accurate cuts. Industrial micrograin carbide teeth offer exceptional wear resistance for long term cutting performance. These fine finish circular saw blades are suitable for use with cordless and corded circular saws, mitre saws and table saws.
For details of each specific blade, see below:
114684: 272.136.36H; 136mm x bore size 20mm (+ 10mm spacer); hook angle 18°; ATB 10°
114685: 272.160.40H; 160mm x bore size 20mm (+16mm spacer); hook angle 16°; ATB 10°
114686: 272.165.36H; 165mm x bore size 20mm (+ 15.88mm spacer); hook angle 20°; ATB 10°
114688: 272.190.42M; 190mm x bore size 30mm (+ 20 and 16mm spacer); hook angle 18°; ATB 10°
114689: 272.216.48M; 216mm x bore size 30mm; hook angle -5°; ATB 10°
114690: 272.250.50M; 250mm x bore size 30mm; hook angle 15°; 4 ATB 10° and 1 flat
114691: 272.250.60M; 250mm x bore size 30mm; hook angle 15°; ATB 10°
114692: 272.305.72M; 305mm x bore size 30mm; hook angle -5°; ATB 10°
